Thanks,
Will check out the warranty as it is back in the shop this am.
A chance to see how good my warranty really is.
Thanks for all the help, it is appreciated.
Wednesday, May 13th, 2009 AT 1:41 PM
DOCFIXIT
MECHANIC
Good luck lets us know what they come up with. Will advise if it seems right.
SPONSORED LINKS
Thursday, May 14th, 2009 AT 8:23 AM
PRP2298
MEMBER
Just got call from shop. They said internal split shaft with three oil seals had center seal bad which is causing problem. They are in the process of replacing it now. Say it takes a total teardown of tranny again.
Sound like this could be it?
Thursday, May 14th, 2009 AT 5:06 PM
DOCFIXIT
MECHANIC
Yes indeed check post May 13, 2:31 see I mentioned the oil seals That is what they found.
Friday, May 15th, 2009 AT 7:09 AM
PRP2298
MEMBER
Good Call, sounds like you were right on the money. Where are you located? You said check the 2:31 answer, but it got to me here in Wa. State at 10:31.
Thanks again.
