It might have been 1320, I erased the code and cannot get it to start to check it again. Help!
Friday, August 27th, 2010 AT 6:41 PM
BLUELIGHTNIN6
MECHANIC
Take the cap off the distributor and see if the rotor is turning when you crank. If it is, then check all fuses and check connections. If not then replace the timing belt.
