1993 Mercury Tracer Won't Shift
MOOSE5255
I have a 1993 Mercury Tracer, (station wagon) 4 cylinder (2.3 liter) and the car has 146,000 miles on it. The car has a "new" tranny taken from a junk car, the original had a major meltdown and it needed to be replaced, so my mechanic friend replaced the original with one from another Mercury Tracer which had approximately 70,000 miles on it. My problem is, the transmission (they call it a trans axle I guess) is acting up. It takes off in first gear fine but won't shift. If I put it in neutral then back to drive (the drive that shows the "D" in a circle) then it shifts to the next gear. BUT, after a few seconds it slips out of gear. Then I repeat the process and again, it shifts to the next gear only to slip out again! Now, after awhile it will down shift by itself, stay that way for a few seconds, then it will straighten out and shift through the gears just fine. Sometimes it takes only once or twice to get it to shift correctly, but other times it will do this for up to 5 or 10 miles. It is strange and frustrating, even to my mechanic who is very good. The gears do not slip, it just pops out of gear. It's very annoying and also I'm afraid it might be a prelude to a major problem. Do you have any suggestions? Thank you in advance! (P.S. I am a disabled person on a fixed and very tight income, but will make whatever donation I can when I receive my monthly check for November 2007. Right now though I desperately need my car).
Oct 28, 2007 at 10:09 PM
2CARPRO JACK
  • 11,533 POSTS
Assuming that you did service the trans, so a plugged filter isnt an option. Could be a sticky governor or something in the valve body from the trans sitting for a while. Try a flush, it might help free up whatever the problem may be
Oct 29, 2007 at 3:36 AM
MOOSE5255
[quote:7c6bc65fbf="2CarPro Jack"]Assuming that you did service the trans, so a plugged filter isnt an option. Could be a sticky governor or something in the valve body from the trans sitting for a while. Try a flush, it might help free up whatever the problem may be[/quote:7c6bc65fbf]
Yes, the transmission fluid was drained, filter replaced with a new one. How do I flush the tranny, and What do I use to flush it, and do I need to replace the filter again after it has been flushed? Thank you.
Oct 29, 2007 at 3:47 AM
2CARPRO JACK
  • 11,533 POSTS
A trans shop will have the right equipment to do a full flush......might help and might not.
Oct 29, 2007 at 4:06 AM
MOOSE5255
[quote:a0a1524d6f="2CarPro Jack"]A trans shop will have the right equipment to do a full flush......might help and might not.[/quote:a0a1524d6f]
Thanks so much I appreciate your suggestions. Will let you know if flushing it helps out. Thanks again!
Oct 29, 2007 at 9:44 AM
RODBEARING
i have the same exact problem with my 93 tracer, i found some bad vacuem lines i thought,might be the problem ,but it was not,my next move is tranny flush,fluid filter,somthing is not telling this tranny to shift,i will let you knowif i fix this thing
Oct 3, 2008 at 2:00 PM
Suggested Repair
Have a transmission shop perform a full fluid flush. The used transmission may have a sticky governor or valve-body issue from sitting; a flush might free it, but it is not guaranteed.
Conversation Summary
A 1993 Mercury Tracer with a used replacement transaxle takes off in first but will not upshift until shifted to neutral and back to Drive, then pops out of gear. After several miles it may begin shifting normally. Fluid was drained and the filter replaced. The expert suggested a sticky governor or valve-body problem and a professional full flush, which may or may not help. Another owner reported the same symptom after checking vacuum lines.
