99 Mercury Tracer Automatic Tranny probs
1999 MERCURY TRACER
DARKCHYLDE
Hi there. I bought a 99 Tracer LS from a used car dealer, and he told me that there was a problem with the tranny. He said it had problems shifting in the cold, but told me that after servicing it, he only had problems with it shifting into OD. He told me it needed a new "shift module" which I can only assume means it needs a new TCM. If this is the case, would that cause the car to shift normally but not go into OD? If not, what else do you think could be the problem?
Apr 28, 2007 at 6:01 AM
MERLIN2021
  • 17,250 POSTS
If the TCM is bad all shift are affected...OD is OD problems going into OD means OD clutch is going or gone...
Apr 28, 2007 at 3:22 PM
DARKCHYLDE
So, would I be okay to just get a rebuild kit with clutches or should I go with a rebuild kit with clutch and steel plates? I'm not too sure as I dont work on cars alot, but I want to try and do this myself and not spend an arm and a leg at a shop.
Apr 29, 2007 at 3:02 AM
