1989 Mercury Tracer Key Won't Turn
TAMMYWORLDS34
I have a 1989 Mercury Tracer mileage 66512. The key goes in the ignition and the steering wheel is locked, the car is in park but when I try to start it the key won't turn.
It is like something is blocking it. Can you help me with this, or tell me how to take the steering column off to see if anything is out of alignment that may be blocking it.
Thank you
Tammy
Apr 11, 2006 at 2:42 AM
PEPPERMRJ
  • 1,158 POSTS
Sometime when the wheel is turn and tight like up against a curb it can take some real muscle to turn the wheel slightly to let the key turn freely. Try this first.
Good luck and let us know. :)
Apr 11, 2006 at 3:07 PM
Suggested Repair
If the steering wheel is loaded against the lock, such as after parking against a curb, turn the wheel slightly with firm pressure to relieve the bind so the ignition key can turn freely.
Conversation Summary
The owner of a 1989 Mercury Tracer with 66,512 miles says the key inserts but will not turn, the steering wheel is locked, and the car is in park. They asked whether something is blocking the lock and how to remove the steering column to check alignment. The expert advised first trying to turn the wheel slightly, which can take some force when it is tight, so the key can turn freely.
