1995 Mercury Tracer Loses Power
PMEDIC74
1995 tracer w 118,000 miles, had a new transmission put in, now it loses power from a battery cable like it has a short in it, if you're driving the car will lose all power and i have to get out and jerk on the battery cable. then it will start, also the windshield wipers will not turn off, they constantly run even when the switch is off.
May 18, 2006 at 8:04 AM
LOSONE
  • 1,616 POSTS
Remove and clean both battery cables. Insure they are tight. Remove and clean the ground cable to the engine, engine to the fire wall and battery to the frame.
Cars are not made to have a battery cable jerked.
May 18, 2006 at 9:55 AM
Suggested Repair
Remove and clean both battery cables and make sure they are tight. Also clean the ground connections from the battery to the engine and frame and from the engine to the firewall. Do not jerk the battery cable to restore power.
Conversation Summary
A 1995 Mercury Tracer with 118,000 miles began losing all power while driving after a transmission replacement, requiring the battery cable to be jerked before it would restart. The windshield wipers also run continuously even with the switch off. The expert advised cleaning and tightening both battery cables and the ground connections at the engine, firewall, and frame.
