1994 Mercury Sable Speedometer Wobbles
GDUBBS142
I have a 1994 mercury sable with a 3.0 and about 50,000 miles and the speedometer is iratic after I go over 40mph. It actually bounces up and down off of the dash where the speedometer is at 85mph when I am going any speed over 40 or so. It also makes a grinding/fast ticking noise behind the dash. What do I need to do to repair this issue and how is it done?
Mar 25, 2007 at 9:26 AM
MERLIN2021
  • 17,250 POSTS
what it is is the inner cable. You have to reach up and unscrew the cable from the speedometer pull out the old cable and put in a new one.
Mar 25, 2007 at 9:56 AM
PERRATZO
  • 7 POSTS
I'd try lubing the cable first.
These cables are like brake cables on a bicycle. sometimes the inside begins to rust.
The good news is that you can prevent further damage by lubing the cable as soon as the wobble is noticed by the shaky speed needle. No new cable needs to be installed.
The bad news is that if you let this wobbling go on until noise appared and then became unbearable, the inside of the cable is most certainly gone the way of the dodo. Get new cable pronto.
Jul 9, 2010 at 7:19 AM
MERLIN2021
  • 17,250 POSTS
Thanks for helpin' out, but you are three years too late!
Jul 9, 2010 at 8:58 AM
PERRATZO
  • 7 POSTS
Oh, I know. But these pages keep getting read on, right?
So why not expand on them a bit?
I think I'ĺl try those without answers. Some of them are pretty good questions and no one bothered to reply.
Jul 9, 2010 at 10:52 AM
MERLIN2021
  • 17,250 POSTS
Good idea! Usually if the poster doesn't ask a follow up, his problem is solved.
Jul 10, 2010 at 1:27 AM
Suggested Repair
Replace the inner speedometer cable. Unscrew the cable from the speedometer, pull out the old cable, and install a new one. Lubrication may help early needle wobble, but grinding or ticking noise indicates the cable is already damaged and should be replaced.
Conversation Summary
A 1994 Mercury Sable with a 3.0 engine has an erratic speedometer above about 40 mph, with the needle bouncing and a grinding or fast ticking noise behind the dash. The expert identified a failed inner speedometer cable and advised unscrewing it from the speedometer, removing the old cable, and installing a new one. A later comment suggested lubricating the cable early, but agreed that once noise develops the cable is likely ruined and needs replacement.
