1999 Mercury Sable Door Ajar Light On
CRUSIN5000
Question: 1999 Mercury Sable mileage: 77,000. My interior lights and the "door ajar" light is on all the time while I‘m driving. The Dome light will stay on 30-40 minutes after the car is turned off. In addition, the drive’s door will not lock or unlock by the power lock system. I am guessing these problems are tied in together. The doors are not ajar, so I’m thinking there is something wrong with the sensor. Please help. Thanks.
Mar 2, 2007 at 3:23 PM
CHEVY22
  • 1,375 POSTS
hi ,the two problems may not be related , the door ajar switch is faulty , it is actually in the door latch assembly , the lock problem may be a door lock actuator inside the door panel , usually you can hear it if you listen close but it will not move the lock
thanks jim
Mar 2, 2007 at 3:34 PM
Suggested Repair
Replace the faulty door ajar switch in the door latch assembly. Treat the power lock issue separately: listen at the door for the lock actuator; if it clicks but does not move the lock, replace the actuator inside the door panel.
Conversation Summary
A 1999 Mercury Sable owner reported that the interior lights and door ajar light stay on while driving, the dome light remains on 30-40 minutes after shutdown, and the driver's door will not lock or unlock with the power locks. The expert said the issues may be unrelated: the door ajar switch in the door latch assembly is faulty, and the lock problem may be a door lock actuator that can be heard but does not move the lock.
