2003 Mercury Sable Blend Door No Heat or AC
FORD
PDMARCH2002
I have a 03 sable 52000 mi. 24 valve . Has automatic climate control. It worked fine tilll 3 wks. ago. The a/c is charged and lines cool under the hood.,but no cold air in car. Also no hot air at the floor when heater is on But heat at the upper vents is good. Ford dealer said the blend door was warped. They replaced the door. It worked for a 3 days, and did the same thing, I took it back to them ,they worked on it 3 hours or so and said foam got behind door. It worked ok for a few days and now no a/c or heat at the floor again. I can see a lever moving at the heater case under the dash when I push in the buttons for lower heat. What can I do to fix, Is this a problem with these cars? SABLEGUY :x
Apr 15, 2007 at 12:24 PM
MERLIN2021
  • 17,250 POSTS
There is a small electronic door control box by the gas pedal end, unbolt it and move the door manually, see what happens.
Apr 16, 2007 at 12:51 AM
PDMARCH2002
For merlin2021, I can not see any electronic door control box near the gas pedal side. I do see a box faceing the rear with a slotted link and wires
Apr 16, 2007 at 2:38 AM
MERLIN2021
  • 17,250 POSTS
watch the box when you turn control knob on dash, foes it turn the door arm? if not take it off and move it by hand.
Apr 16, 2007 at 8:37 PM
PDMARCH2002
MERLIN I have push bottons no knobs for the auto climate controls,but I don't see any movement when buttons are pushed on the slotted silver link, the one faceing rear from the box with a wire harness too it . I do have movement at the top left lever.That one moves too different positions. I have some air at bottom vents but not hot air. Same condition at top vents,and temp on dig. read out is 90. IF I set it to 60 for a/c ,there is no a/c air it is warm air. Like I said it was at dealer 2 times 1st said it was blend door 2nd time said it was foam caught in some thing. One other thing is the battery was replaced right before I had all this trouble, Try to give some more of your throughts on this THANKS PAUL
Apr 17, 2007 at 12:23 AM
MERLIN2021
  • 17,250 POSTS
well the box with the wires is what controls the door. Take it off and move it by hand...see what happens!
Apr 17, 2007 at 1:53 AM
Suggested Repair
Remove the wired blend-door actuator box and move the door by hand. If the door moves freely and airflow or temperature changes, the actuator or its control is not driving the door.
Conversation Summary
A 2003 Sable with automatic climate control has no cold air and no hot air at the floor, although upper-vent heat is good. A dealer replaced the blend door and later cleared foam, but the problem returned. The owner sees movement at an upper lever but not at the slotted link on the wired actuator box. The expert says that box controls the door and advises removing it and moving the door by hand to see what happens.
