1997 Mercury Sable Window Won't Go Up
CARDOJ
Q. I have a 1997 Mercury Sable,V-6, automatic transmission, 92,000 miles with P/S and A/C. The driver's power window will not come up. All other windows are fine, up and down. I replaced the power window relay fuse under the hood and under the dash,I also replace the motor check the regulator and switches I can hear a click when I push the button to move the window, but it does not come up. Are you able to help me?
Thank you Jose
May 25, 2007 at 11:47 PM
2CARPRO JACK
  • 11,533 POSTS
Looks like your window wiring goes through the Generic Electronic Module located under left side of instrument panel. This could very well be the problem
May 27, 2007 at 1:22 AM
ZEKE1450
  • 5 POSTS
I have the exact same problem!!
Jun 2, 2007 at 1:32 PM
Suggested Repair
Inspect the Generic Electronic Module under the left side of the instrument panel, since the driver's window wiring passes through it and a click with no window movement can indicate a GEM fault.
Conversation Summary
The owner of a 1997 Mercury Sable reported that the driver's power window would not rise while the other windows worked. After replacing the power window relay and fuses, replacing the motor, and checking the regulator and switches, a click was heard but the window still did not move. The expert said the window wiring runs through the Generic Electronic Module under the left side of the instrument panel and that the module could be the problem. Another user reported the same symptom.
