1993 Mercury Sable Overheating
DEGOUDE
1993 Mercury Sable; 3.8L; temperature increases and decreases while driving. Fan operates. Thermostat is new. Notice that the top radiator hose was collapsed after cooling off. Could this indicate a bad radiator cap?
Thanks
May 24, 2007 at 10:53 AM
  • 75,988 POSTS
[quote:c572546662="degoude"]1993 Mercury Sable; 3.8L; temperature increases and decreases while driving. Fan operates. Thermostat is new. Notice that the top radiator hose was collapsed after cooling off. Could this indicate a bad radiator cap?
Thanks[/quote:c572546662]
Cheap fix replace the collasped hose and the rad cap.
May 25, 2007 at 6:04 PM
Suggested Repair
Replace the collapsed upper radiator hose and the radiator cap.
Conversation Summary
The owner of a 1993 Mercury Sable 3.8L reports that the temperature rises and falls while driving. The cooling fan works and the thermostat is new, but the upper radiator hose collapses after the engine cools. The owner asks whether a bad radiator cap could be the cause. The expert recommends replacing both the collapsed hose and the radiator cap as an inexpensive fix.
