1989 Mercury Sable Overheating
Suggested Repair
Replace or test the thermostat, which is likely stuck closed or partially closed. Also check the coolant level; a leaking heater core can lower coolant and contribute to heat but will not by itself cause overheating. Heater core replacement is a major job on this car.
Conversation Summary
A 1989 Mercury Sable 3.0 with 150,000 miles overheats after the gauge briefly reaches normal, even though the cooling fan and water pump appear to work. The owner suspected a stuck-open thermostat and a leaking heater core because the heater smells of antifreeze. The expert said the thermostat is more likely stuck closed or partially closed, and that a leaking heater core can cause low coolant and heat but will not alone cause overheating. Replacing the heater core was described as a large job.
