1992 Mercury Sable Hard Jolt on Acceleration
NOSNLEFT
my 1992 Mercury Sable sometimes jolts really hard when I accelerate. The RPM also jumps up really high too when this happens. I'm assuming this is becasue of the transmition, but I was wondering if changing the transmition fluid or the filter would help at all. Also, recently I noticed my car making a buzzing noise (almost like a fly by your ear) when it is in park. Thanks for your help.
May 27, 2006 at 7:46 AM
LOSONE
  • 1,616 POSTS
You should alwasy give engine and car mileage when you make a post.
That buzzing sound is you tranmission or power steering pump they both make the same noise.
Once a transmission slips one time the bands are burnt. It will be a waste of time and money to change the fluid as it is already too late. Those trannys should be servcied at 40-50K miles and no later if not you will have the problem you are having now. You need an overhaul Good luck
May 27, 2006 at 8:59 AM
Suggested Repair
Have the transmission overhauled. A fluid or filter change will not help once it has slipped and the bands are burned. The buzzing in park may come from the transmission or the power steering pump.
Conversation Summary
The owner of a 1992 Mercury Sable reports hard jolts and high RPM jumps during acceleration, suspects the transmission, and asks whether changing the fluid or filter would help. A buzzing noise in park is also noted. The expert says the noise could be the transmission or power steering pump, that slipping has already burned the bands so a fluid change is too late, and that an overhaul is needed. These transmissions should have been serviced by 40,000 to 50,000 miles.
