1996 Mercury Sable Headlights Stay On
DREAMCTCHR67
I have a 96 mercury Sable ,3. engine, 113,000 miles.
The headlights will not turn off. The lights stayed on when I took the fuses out. I only got them off by disconnecting the battery. Any ideas on what could be wrong? Somone told me it could be the headlight switch...do they mean the actual switch thats inside to turn the lights on and off?...or something under the hood?
Any help would be appreciated.
Thank You
Apr 9, 2007 at 5:56 PM
MERLIN2021
  • 17,250 POSTS
No they mean the on off switch in the car. Try unplugging the harness from it then connect the battery. If they stay off you found the problem. If they come on you have a short after the switch.
Apr 10, 2007 at 6:50 AM
Suggested Repair
Unplug the interior headlight on/off switch harness, reconnect the battery, and see if the lights stay off. If they stay off, the switch is the problem; if they come on, look for a short after the switch.
Conversation Summary
The owner of a 1996 Mercury Sable reports headlights that stay on even after the fuses are removed and only go off when the battery is disconnected. The expert says the suspected part is the interior on/off switch and recommends unplugging its harness, then reconnecting the battery: lights staying off point to the switch, while lights coming on indicate a short after the switch.
