1995 Mercury Sable No Key Start
KIRB
I have 1 1995 Mercury Sable 289,000 km. The gas gauge is pegged above the full mark and does not work as well the overhead map lights stopped working but not the dome light. I suspect a short circuit somewhere any help on where to check would be great. also the car will not start from the key but will start from the remote car starter.
Mar 22, 2007 at 1:56 AM
MERLIN2021
  • 17,250 POSTS
First pull the fuse to the remote starter and check for start. If this was installed incorrectly, it can cause anything from melted,burned wires, to ruining the PCM!
Mar 22, 2007 at 6:06 AM
Suggested Repair
Pull the fuse for the remote starter and check whether the car will start from the key. An incorrectly installed remote starter can melt or burn wires and can damage the PCM.
Conversation Summary
The owner of a 1995 Mercury Sable reported a gas gauge stuck above full, inoperative overhead map lights with a working dome light, and a no-start from the key although the remote starter still starts the car. The expert advised pulling the remote starter fuse and testing the key start, warning that a faulty installation can burn wiring and ruin the PCM.
