1999 Mercury Sable Cold Brake Lockup
Suggested Repair
With the car in neutral, jack one wheel at a time and open the bleeder. If the wheel then turns freely, replace the brake hose; if it stays tight, replace the caliper. For no heat, have a radiator shop flush the heater core and change the coolant yearly; replace the heater core if it is leaking.
Conversation Summary
A 1999 Mercury Sable locks the brakes when cold, smells of burning brakes, then drives normally after warming up, and also has no heat despite two thermostat replacements and no coolant leaking into the cabin. Experts advised checking whether all wheels or only the front or rear lock, then isolating a stuck hose versus caliper by opening each bleeder. They also said only a heater core can put coolant inside the car and recommended flushing or replacing it. A later owner of a 1992 Sable reported the same brake issue after replacing hoses, calipers, rotors, and pads, with no confirmed resolution.
