1994 Mercury Sable Rear Brake Screech
DEADAIM
When I'm driving I hear a screeching noise coming from the back not sure exactly what is is. It is when I apply the brakes. It you could help that would be great I appreciate it. :D
Jan 4, 2007 at 2:40 PM
TAURUSWHEEL
  • 718 POSTS
Could be brakes, what do you have, 4 disc or 2+2 ???
Jan 5, 2007 at 9:56 AM
DEADAIM
I have 4 disc brakes. Thanks for the help.
Jan 7, 2007 at 7:57 AM
SERVICE WRITER
  • 9,123 POSTS
It's the kids, stop driving so crazy!!! :lol:
HAve someone else drive and have them hit the brakes as they pass you in a parking lot or street. You stand outside and listen for which side.
How old are the rear pads? Maybe warning senor touching the rotor.
Jan 7, 2007 at 9:33 AM
DEADAIM
Thanks so much for your help I appreciate it a lot.
Jan 7, 2007 at 3:31 PM
SERVICE WRITER
  • 9,123 POSTS
What did you find out? :?:
Jan 7, 2007 at 9:19 PM
DEADAIM
Thanks it was the left side. It was the warning sensor touching the rotor. Thanks again appreciate the help. :D
Jan 7, 2007 at 10:33 PM
Suggested Repair
The rear brake-pad wear warning sensor was contacting the left rotor. Replace the worn rear brake pads (and service the rotors if scored) so the sensor no longer rubs.
Conversation Summary
A 1994 Mercury Sable with four-wheel disc brakes made a screeching noise from the rear when the brakes were applied. Advice was to have someone else brake while listening outside to identify the side, and to check rear pad age and whether a wear warning sensor was touching a rotor. The owner confirmed the noise was on the left and that the warning sensor was contacting the rotor.
