97 Sable failed smog test due to troublecodes
STONE57
97 Merc Sable V6 DOHC 105,000 miles failed smog test due to Trouble codes P0761 Shift solenoid C Performance or stuck Off. Another code P1518 shows as well. Any ideas?
Aug 22, 2007 at 7:34 AM
2CARPRO JACK
  • 11,533 POSTS
The shift solenoid problem should be taken to a trans shop to be looked at.The other code is for an intake manifold runner stuck open, there are vacuum actuators that open runners in the manifold under hard throttle, either the vacuum diaphram on one is blown or the plastic bushing on the end is broken allowing the rod to fall out
Aug 22, 2007 at 11:13 AM
