2002 Mercury Sable EGR
CLISCANO
2002 Mercury Sable 6 cyl Automatic 69,000 miles
I had my converter replaced, my intake manifold replaced, solenoid replaced, and the EGR sensor was replaced twice because something was causing it to melt the problem I'm having now is the hoses that connect the EGR sensor keep popping off and is making a loud air sound my car can not pick up speed and it shakes a little. What cause the hoses to pop off? Something else clogged? How will i know? When i get the engine light checked the only codes that comes up is the EGR vavle.
Aug 4, 2008 at 3:12 AM
BMRFIXIT
  • 19,053 POSTS
Are u using regular hoses to connect the sensors if so u need to get the correct ones from the dealer
regular vacuum hose will burn with time, causing the sensor to melt
also check exhaust back pressure
check tune up and firing order
check mass air flow sensor
Aug 4, 2008 at 6:16 AM
