Engine stalls intermittently and shows codes p0191 and p1237?
Thursday, January 7th, 2010 AT 1:36 PM
BLUELIGHTNIN6
MECHANIC
Both codes indicate fault with the fuel pressure. Check fuel pump relay. Most likely it is sticking and causing fuel pump to turn off during operation. If relay is OK then pump is failing.
