engine shuts off when car is stopped
160,000 MILES
MAND8945
when I stop at red lights or stop signs, my car sounds like gas isn't getting through and it shakes a bit then the engine will shut off. It turns right back on, and is not a problem while the car is moving, it only shuts off when the car is stopped, but not every time. It's unpredictable. When I had the code from the check engine light checked, it said something about the gas line.
Jul 25, 2013 at 7:34 AM
CJ MEDEVAC
  • 11,000 POSTS
DOES THIS SOUND LIKE YOU?
https://www.2carpros.com/questions/2005-ford-escape-every-day-crank-suv-high-idle-usually-after-30-minutes
USE THROTTLE BODY CLEANER TO CLEAN IT
IF YOU NEED MORE EXPLANATION ON THE PROMO THING....JUST ASK......"A124" WAS WORKING YESTERDAY
LEMME KNOW HOW THINGS ARE GOING....THIS IS EZ TO DO ON YOUR OWN OR WITH A MECHANICAL BUDDY
MAYBE IT'S JUST THIS SIMPLE!
THE MEDIC
Jul 25, 2013 at 1:06 PM
