1999 Mercury Sable (Interior light problem)
CRUSIN5000
Question: 1999 Mercury Sable mileage: 77,000. My interior lights and the "door ajar" light is on all the time while I‘m driving. The Dome light will stay on 30-40 minutes after the car is turned off. In addition, the drive’s door will not lock or unlock by the power lock system. I am guessing these problems are tied in together. The doors are not ajar, so I’m thinking there is something wrong with the sensor. Please help. Thanks.
Mar 2, 2007 at 3:23 PM
CHEVY22
  • 1,375 POSTS
hi ,the two problems may not be related , the door ajar switch is faulty , it is actually in the door latch assembly , the lock problem may be a door lock actuator inside the door panel , usually you can hear it if you listen close but it will not move the lock
thanks jim
Mar 2, 2007 at 3:34 PM
