1998 Mercury Sable Trannsmission just stop
FONZODJ
  • 1998 MERCURY SABLE
  • 6 CYL
  • FWD
  • 156,000 MILES
I just pulled up in my drive way and now when I go out to start it up. It will not go in reverse forward nothing I changed the filter in the trannsmission but still same problem
Tuesday, September 22nd, 2009 AT 1:42 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Whatcolor was old fluid? Smeel burnt? Is linkage hooked up? Will car roll in neutral?When in gear does it seem like neutral or like parking brake on?
Let me know
Thanks for donate
Tuesday, September 22nd, 2009 AT 2:02 PM
FONZODJ
It was brownish the tran gave no indicatin that it was goin out It will roll in neutral and linking is hook up
Tuesday, September 22nd, 2009 AT 2:14 PM
FONZODJ
When in gear it feel like it is in neutral
Tuesday, September 22nd, 2009 AT 2:16 PM
DOCFIXIT
  • 18,828 POSTS
Need pressure test to tell what happened but expect a major repair. Maybe the EPC solenoid stuck not allowing line pressure.
Tuesday, September 22nd, 2009 AT 2:23 PM
FONZODJ
Ok thanks but do you think it in my transmission are the engine
Tuesday, September 22nd, 2009 AT 5:24 PM
DOCFIXIT
  • 18,828 POSTS
No it is the trans
Thursday, September 24th, 2009 AT 11:55 AM
BIERMANN58
That is similar to mine. It did same thing. The transmission had to be rebuilt due a wear problem that was corrected in later models. Cost $2400.
Saturday, October 3rd, 2009 AT 4:12 PM
