I question a couple things. First, when it won't start, can you hear the fuel pump kick on when you first turn the key on?
When these things happen, it is usually the result of a loss of fuel to the engine or spark. Which you are loosing, I'm not sure but will provide directions on how to check later. If it is only one or the other, I need to know. If you are loosing both, there is an electronic engine control (EEC) relay in the relay block under the hood that may need replaced (about a 5 dollar part). I need to have you check to see which is missing and let me know. Also, let me know if your check engine light has ever come on?
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know,
SPONSORED LINKS
Wednesday, January 13th, 2010 AT 8:28 PM
