1999 Mercury Sable Car starts then dies a second later
GACYOTA
  • 1999 MERCURY SABLE
  • 6 CYL
  • FWD
  • 98,000 MILES
I had to replace the front crank seal because it was leaking. I had to replace the harmonic balancer in the process (I accidentally dropped original and cracked exciter ring). After putting car together, it started, but will only run for a second then sputter and die. My first thought was a crank sensor, so I replaced it and have same issue. I of course have double and triple checked that all of my sensors are hooked back up and everything appears to be where it is supposed to be. I have no MIL so my $100 scanner won't tell me what's wrong. Where do I go from here to diagnose this problem?
Saturday, September 11th, 2010 AT 9:26 PM
Check the fuel pressure if its within specs if normal-clean the idle air control valve, EGR valve and use an electronic cleaner CRC on the MAF sensor and also might just wanna test the TPS sensor too-
Saturday, September 11th, 2010 AT 10:41 PM
GACYOTA
Car is fixed. After doing spark test, relay switching, rechecking vacuum and sensor connections, I looked on the bench of remaining bolts and noticed a washer that looked like it would fit on a harmonic balancer bolt. Installed washer, started car, purring like a kitten.
I am happy to say the Sable is on the road tonight.
I guess not having that washer there was binding up the crankshaft?
Sunday, September 12th, 2010 AT 9:34 PM
Happy motoring and good luck
Sunday, September 12th, 2010 AT 10:30 PM
Related Engine Stall While Driving Content
