1984 Mercury Sable Battery vs Alternator
JERRYTHEK
  • 1984 MERCURY SABLE
  • 6 CYL
  • 10,000 MILES
Hi!
My Mercury Sable is my backup car, and sometimes sits as long as a week without use. I live in CT and the late winters can be cold.
My battery is less than a year old, and recently I tried to start my car and it wouldn't turn over, after almost catching. I jump started it with cables, it started almost right away, I ran it on the highway for 30 minutes, and it was fine. Drove it a couple of times in the next day or so, and it started right away.
It then sat for another 5 days without being started, and wouldn't turn over. Seems like the battery just drained, even though the weather wasn't very cold over those 5 days.
The battery is under warranty, but I believe my alternator is fine, since it jumped ok and ran as I described.
My fear is that the garage that sold me the battery under full warranty will try to tell me I need a new alternator instead of replacing the battery for free.
What are my options, and is there someway from what I describe that you can tell its the battery and not the alternator?
Thanks!
Jerry
Monday, April 13th, 2009 AT 11:01 AM
BMRFIXIT
  • 19,053 POSTS
I would not suspect an alternator
but I will still give it a check
I would suspect a battery and or something is draining the battery
and need to do a battery draw test
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Tuesday, April 14th, 2009 AT 9:46 PM
