Mercury Wipers Won't Shut Off
MERCURY
KYJIMBO
My windshield wipers will not turn off when I have washer fluid in the resevoir. What is causing my wipers to be continually on until all my washer fluid has run out?
Nov 22, 2006 at 12:30 AM
MERLIN2021
  • 17,250 POSTS
try tapping on the lever a few times to shut them off. If not the switch is NG
Mar 5, 2007 at 10:52 AM
BHUGG
  • 157 POSTS
It dosen't make sense that the wiper motor has anything to keep the wipers on.
I suspect that you have a defective interval wiper module or switch.
Good Luck.
Mar 5, 2007 at 4:27 PM
Suggested Repair
Tap the wiper lever a few times to see if the wipers shut off. If they do not, inspect and replace the defective wiper switch or interval wiper module rather than the wiper motor.
Conversation Summary
A Mercury owner reported that the windshield wipers stay on whenever washer fluid is in the reservoir and continue until the fluid runs out. One expert suggested tapping the control lever and replacing the switch if that does not stop them. Another said the motor is unlikely to cause this and suspected a defective interval wiper module or switch.
