1985 Honda Accord...just started blowing the windsheild wiper 15a fuse. Is there a way to bypass and run straight off the battery?
Feb 21, 2006 at 12:30 AM
Disconnect the windshield wiper motor and install a new fuse. If the fuse still blows, the wiring is at fault. If it holds, the wiper motor is faulty and should be replaced.
The owner of a 1985 Honda Accord says the 15-amp windshield wiper fuse has started blowing and asks whether the circuit can be bypassed and powered directly from the battery. The expert says a blown fuse indicates a fault and recommends disconnecting the wiper motor, then installing a new fuse. If the fuse blows with the motor disconnected, the wiring is the problem; if it does not, the motor is faulty and needs replacement.
