1999 Mountaineer Cold start issue
YACO
Past few days in the morning if I go to start the truck it may or may not start unless I put my foot on accelerator.Will run fine after a few seconds if I let it "Warm up". 5 -8 sec
It may take 2-3 times if I take off my foot it dies. Most of the time it will start fine.
I checked the IAC and cleaned it, it did not seem too dirty.
I also added a ACCEL Permanant Air filter(K&N Type)a few weeks ago with the proper amount of oil to the filter. I wounder if I should clean the MAF or replace it.That never was an issue and truck ran fine for days with the filter.
Any insight? 86'000 miles on it temps 50-70 in the morning recently.
Oct 19, 2007 at 3:27 AM
BLACKOP555
  • 10,386 POSTS
i woudl check and clean the MAF also i would check the coolant temp sending unit which could be sending a too cool or too hot temp to the ECM.
Oct 19, 2007 at 3:32 AM
YACO
[quote:311c204ca1="blackop555"]i woudl check and clean the MAF also i would check the coolant temp sending unit which could be sending a too cool or too hot temp to the ECM.[/quote:311c204ca1]
I'll try the MAF next. Then I'll check the sender for Cool Temp sending unit.
Thx
Lee :)
Oct 19, 2007 at 9:20 PM
BLACKOP555
  • 10,386 POSTS
remember dont touch the wires on the MAF with your hands! only spray them with gd cleaner
Oct 19, 2007 at 11:58 PM
YACO
[quote:57938c8663="blackop555"]remember dont touch the wires on the MAF with your hands! only spray them with gd cleaner[/quote:57938c8663]
I cleaned the MAF still get the intermottant problem. I will try the coolant sensor next but I see 2 contenders that look exactly the same.
both are on the intake manifold one to the Driverside closer to the front .The second to the pass side closer to the Injectors.
$22.00 part no big deal but want to eliminate anything else. I'm always pressing accelerator out of habit when I start it up now :)
Nov 7, 2007 at 7:20 AM
YACO
It appears to be the IAC. After going to work in 31 degree temps I had to have my foot on accelerator or stall would occur.
I got to work and when it warmed up out side I started but was still @ 300 +/- RPM and would stall in 10 secs or so.
I unplugged the IAC and no difference I plugged it back in same. I tapped it with a screw driver and VOLIA!
RPMs went to norm. I cleaned it again and orderd a new one from ROCKAUTO.COM for $43 with shipping.
Thx Guys!
Lee :) :P
Nov 17, 2007 at 7:52 AM
