1997 Mercury Mountaineer No Start
ROGERBOSTIC
I have a 1997 mecury mountaineer with 10700 miles on it. Some of the times, when I go somewhere and shut off the engine, and then try to start it back up, it won't start. You can hear the soylonoid clicking, but it still won't start. I replaced the soylonoid, and it still won't start. What do I do next?
Nov 18, 2006 at 2:42 AM
MERLIN2021
  • 17,250 POSTS
Check the battery cables especially the neg cable to engine block connection. If they are good take a look at the starter motor...sounds like it's getting to hot! If it's the starter put in a new one.
Mar 9, 2007 at 5:43 AM
Suggested Repair
Check the battery cables, especially the negative cable connection to the engine block. If the cables are good, inspect the starter motor; heat-related starter failure is possible, and a faulty starter should be replaced.
Conversation Summary
The owner of a 1997 Mercury Mountaineer reports that the engine sometimes will not restart after being shut off. The solenoid clicks, and replacing the solenoid did not fix it. The expert advises checking the battery cables, particularly the negative cable to the engine block, then inspecting the starter motor because it may be overheating and need replacement.
