1999 Mercury Mountaineer overdrive light flashing on/off
148,000 MILES • V8 • FWD • AUTOMATIC
TWYCHE
smoke coming from engine...what is going on?
Jul 10, 2008 at 12:35 AM
2CARPRO JACK
  • 11,533 POSTS
The OD light flashing is the trans telling you there is a problem.You can have the PCM scanned for the trans code. As far as the engine smoking, is it low on any fluids? any noticeable leaks on the ground? need to know what fluid is leaking, might be trans fluid out of the vent hitting the exhaust
Jul 10, 2008 at 12:56 AM
