1998 Mercury Mountaineer INTERMITTANT TURN SIGNALS
90,000 MILES • V8 • AWD • AUTOMATIC
JOHN_T_65202
I was wondering if anyone has ran into this problem? Sometimes I lose my signal flashers and not even the emergency flashers will work. Unfortunately, the legend for my fuse block is gone, so I don't even know which fuse to check. But, since this is an intermittant problem, I doubt if it's the fuse. Any Ideas would be appreciated.
Jan 28, 2008 at 4:40 AM
JOHN_T_65202
Just found out that they work as long as the tilt is all the way up. So it is probably a connecter in the column coming loose.
Feb 27, 2008 at 7:36 AM
