2003 Mercury Mountaineer cruise, brake lights
2003 MERCURY MOUNTAINEER
127,000 MILES • 6 CYL • AWD • AUTOMATIC
JEFFMCDOWELL
cruise works, then will not engage next time I drive; abs light comes on when it wants to; not the next time; brakes check out fine.
Nov 17, 2009 at 5:58 AM
RICKMAR
  • 170 POSTS
https://images.2carpros.com/forum/automotive_pictures/433905_ABS_Sensor_4.jpg
Indicated by arrow (1) Hold-down Nut Indicated by arrow (2) ((ABS)) Sensor. On the ((ABS)) light, your ((ABS)) speed sensor/sensors (2) in the sketch above could be giving you an early warning. The sensors may also disengage the cruise control. I have heard the rears are most common. There just might be a recall on the ((ABS)) rear sensor/sensors. You should call a local Lincoln/Mercury dealer and give him V.I.N. of your Mountaineer to see if a "recall" was established. If there was it is a safety issue and they have to fix it at no charge to you. Something "IS" not operating correctly in you ((ABS)) system...do not ignore it. It could become a dangerous situation!! I hope this information helped; Rick
Nov 28, 2009 at 1:19 PM
