1994 Mercury Marquis
1994 MERCURY MARQUIS
180,000 MILES • V8 • FWD • AUTOMATIC
NEWBREED
When I first start my car it gives off fumes and i see white smoke. After a while of jus sitting i start to see water dripping for the tail pipes. When i press the gas i see alot of smoke coming from the tail pipes. I have recently notice after i park i have seen what appears to be oil in the spot of the car. Car runs smoothly no noises or ticking recently had flow masters installed. I was wonder if the problem could come from a leak in to the pipes..
Mar 18, 2009 at 3:01 PM
BLACKOP555
  • 10,386 POSTS
add soem water remover from the gas tank. see if that cuts down on the exhaust.
what kind of oil?
if its tranny fluid, or power steering fluid it could be causing the white exhaust.
Mar 19, 2009 at 1:14 PM
