1996 Mercury Cougar P0401 EGR Code
SONJER
1996 mercury cougar 4.6 v8 110000 miles. what problem might i have after p0401 code came up?
Feb 2, 2007 at 12:55 AM
MERLIN2021
  • 17,250 POSTS
you have an egr flow probem, take off egr valve and clear the channel right to the throttle body, I use an old steel coathanger for this, if the channel is not plugged, check the egr valve and the erg position sensor.
Mar 3, 2007 at 11:25 PM
Suggested Repair
Treat P0401 as an EGR flow problem. Remove the EGR valve and clear the passage all the way to the throttle body. If the passage is not plugged, inspect the EGR valve and the EGR position sensor.
Conversation Summary
A 1996 Mercury Cougar 4.6 V8 with 110,000 miles set code P0401. The expert identified an EGR flow problem and advised clearing the EGR channel to the throttle body, then checking the EGR valve and EGR position sensor if the channel is not plugged.
