The check Engine light is on, first I check all the fluids and the levels are fine, then I took for a test drive and it will idle fine, a little rough though, when I press on the accelerator, the check engine light goes out briefly, but then comes back on and the engine looses power or dies, but when the accelerator is released sometimes it will return to a rough idle, i can lightly press on the accelerator and it will go, but as I try to go faster the same happens again. This continues in Reverse as well as Drive. Any help in an idea of the possible diagnosis would be appreciated.
Jul 9, 2006 at 1:56 PM
