Mercedes Benz W202 C180 won't start
250,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
MAVMANGWIRO
I have a C180 Mercedes Benz W202 1999 model. The car has been giving me problems lately. I start the car normally without a problem in the morning, and then drive to work about 7km away. When i park the car for some time and i try to start it again, i get no response, the crack will be there but the engine wont turn. The pump will also be quiet. what could be the problem
Nov 22, 2021 at 4:56 PM
If I understand correctly, when the engine will not start and you turn the key, you don't have anything happen? Meaning the engine will not even turn over and try to start?
So, when you turn the key, nothing happens or does the engine turn over and just not fire?
These are very different issues and here are guides that will help with both issues to better determine what is happening.
If you need to, can you get a video of what the vehicle does when you try to start it and that will help us take the next steps.
Please run through this and let us know for sure and we can go from there.
Thanks
Nov 24, 2021 at 6:22 AM
