Engine Turns but will not starts
139,000 MILES • V8 • 2WD • AUTOMATIC
MAPPY0NE
Hi my name is Serey and I am looking for some trouble shooting help.
I own a 2000 S500 with 139,000 mile plus. Recently, I took my family on vacation and drove from Mass to Florida and back.
Here is the problem that I'm trying to diagnose.
While I was in Florida this problem occured. I drove the car and stopped to have lunch and the engine would not start. It would just turn and turn and turn. My thought was that there might be an ignition system issue since the engine truns but would not fire-up. So I disconnected the negative battery terminal and I pulled the fuse out one by one to see if I have any blown fuses and after about 10 minutes or so it starts just fine.
It started just fine after that until I got back home and the same problem reoccurred 5 or 6 days later but after 6 or 7 times turning the key it started.
Today (4 days later) I drove my wife and children to visit my parents and now it will not start at all. The engine would just turn and turn and turn but will NOT fire-up.
Any ideas as to what could be the source of this ignition problem?
Any help in determining the source of this problem is greatly appreciated.
Thank you!
Best regards,
Serey V. Oum
Jan 9, 2010 at 5:08 PM
  • 75,988 POSTS
No start condition this guide can help us fix it
Jan 9, 2010 at 6:03 PM
MAPPY0NE
2000 Mercedes Benz S500 Engine Turns but will not starts.
Summary update of the above engine problem.
I returned to pick up my S500 from my mom place and was dreading the worse that I have to have it towed to a repair shop but it was not so. It started just fine.
I bought an OBD code reader and the ONLY codes reported were O2 sensors. I did not want to leave it to chance so I replaced the crankshaft sensor anyway after reading about intermittent engine starting issue and that it could be the crankshaft sensor going bad.
Since then the above problem has not re-occurs therefore one can only conclude that it was the crankshaft sensor.
Jan 28, 2010 at 5:23 AM
  • 75,988 POSTS
We appreciate your comeback with the fix thank you
Jan 28, 2010 at 5:37 AM
LOWEEDA HAYMAN
No start condition
My S 500 will not start have not tried to started it in a year. They only problem I ever had with it was the struts. I thought maybe it was the crankshaft sensor . I replaced it and it still will not start. What could the problem be. Also have a fuse that keep blowing under the rear back set.That controls the emergency lights.
Jun 14, 2017 at 1:26 PM
  • 31,937 POSTS
you need to check that you have fuel pressure and probably any fuel left in the tank will have gone bad, replace the fuel filter and make sure that you have good spark, i am thinking that it will be fuel related if it has been sitting for an extended period.
Jun 16, 2017 at 7:49 PM
BRISENO2019
MHPAUTOS what are the globes that you are talking about??
Dec 17, 2020 at 12:53 AM
BRISENO2019
I'm having same issues as original post question with same vehicle. I have changed sensor and checked fuel rail with about 50 PSI.
Dec 17, 2020 at 12:54 AM
  • 55,560 POSTS
Which sensor did you change?
Dec 22, 2020 at 8:31 AM
