2000 Mercedes Benz S500 my car wont start
15,400 MILES • V8 • 2WD • AUTOMATIC
THERDY64
I did not use my car for 3 weeks.and tried to start yesterday but it wont start.Theres no sign of light,wipers,radio and other.When i put the key in ignition key it wont turn.So i decided to use the the jumper with another car.The light went on,rado but it wont start.
Is the battery dead? but how come it wont start even i use jumper with another car? or any electrical problem?
somebody can give me advice,thanks in advance.
therdy64,
May 22, 2010 at 2:17 AM
  • 75,988 POSTS
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
No crank at all/nothing/nada:
Could be a blown fusible link,the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good
May 22, 2010 at 5:11 AM
