Check engine light on:
P0170 Fuel Trim Malfunction (Bank 1)
P0440 Evaporative Emission Control System Malfunction
Is this critical? What is the resolution?
Address the codes promptly. For P0440, check that the gas cap is installed and sealing, and inspect the purge solenoid and EVAP canister. For P0170, confirm the code and inspect the bank 1 oxygen sensor and related fuel-trim components.
The owner of a 1999 Mercedes SLK230 with 77,750 miles reports a check engine light with P0170 fuel trim malfunction on bank 1 and P0440 evaporative emission system malfunction, and asks whether it is critical. The expert associates P0170 with the bank 1 oxygen sensor and questions whether that code is correct. For P0440, the expert lists a loose or faulty gas cap, a failed purge solenoid, or a plugged canister as possible causes, and advises addressing the problem soon rather than waiting for it to worsen.
