1972 Mercedes 230 Overheating
MERCEDES BENZ
ZX1
Hi its my first post i have a 1972 mercedes 230/6
the radiator pipe bust yesterday and it over heated right up to the red now i repaired the pipe an filled with water i left the cap of and started it the water runs out of the cap .i know thats not good news as it might need a new gasket an head pulled off .but a friend of mine said that i must bleed the water system ?i noticed on the thermostat housing ther is a nut now how do i bleed this system i'v never heard of this before please can you give me some info as i dont want to pull the head off . thanks in advance
Nov 9, 2006 at 8:21 PM
2CARPRO JACK
  • 11,533 POSTS
Engine off, remove the nut ad fill the radiator until coolant comes out of the hole
Nov 16, 2006 at 2:36 AM
ZX1
[quote:726e21c604="2CarPro Jack"]Engine off, remove the nut ad fill the radiator until coolant comes out of the hole[/quote:726e21c604]
Thanks i did that and it works perfectly does not
overheat and its running sweeeeet . For now anyway
Nov 17, 2006 at 6:27 AM
Suggested Repair
With the engine off, remove the bleed nut on the thermostat housing and fill the radiator until coolant comes out of the hole, then reinstall the nut.
Conversation Summary
A 1972 Mercedes 230/6 overheated after a radiator pipe burst. After the pipe was repaired and the system refilled, coolant ran out of the open radiator cap when the engine was started. The owner was advised to bleed the cooling system with the engine off by removing the thermostat housing nut and filling until coolant came out of the hole. The owner reported that this stopped the overheating and the engine ran normally.
