1994 Mercedes Benz 320e won't start
BUNGALOE
  • 1994 MERCEDES BENZ E320
1994 Mercedes Benz 320e Two Wheel Drive Automatic
we installed a new battery.
we installed a new starter.
it started for a couple days and now I can't get it to crank is there a relay or electrical component that may be the problem? Or maybe it could be something else?
Saturday, February 20th, 2010 AT 7:06 PM
2CARPRO JACK
  • 11,533 POSTS
I apologize for the delay. First off, will it crank in neutral? If so theneutral safety switch (trans position sensor) is probably bad. If not go to starter and test small wire with test light, if no power in crank position it may be a bad starter lock-out relay module, it is located behind the left side of theinstrument cluster. Also check fuse #5 in the fuse panel
Wednesday, February 24th, 2010 AT 7:45 AM
BUNGALOE
Yes it ended up being the neutral safety switch.
Wednesday, February 24th, 2010 AT 9:01 AM
2CARPRO JACK
  • 11,533 POSTS
Glad to hear your back on the road
Wednesday, February 24th, 2010 AT 10:40 AM
