engine not starting
214,564 MILES • 1.0L • 6 CYL • FWD • AUTOMATIC
RACINE
My car at times starts right away, then it may take ten to thirty turns of the key to start. Then again may take a few hours or overnight. Battery, starter good.
Apr 9, 2017 at 9:27 AM
  • 55,834 POSTS
We must see which system is failing to get a handle on whats going on, here is a guide that will guide you in the right direction.
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Apr 12, 2017 at 11:40 AM
RMONKELIS
Engine Mechanical problem
1997 Mercedes Benz 320e 6 cyl All Wheel Drive Automatic 90000 miles
I bottomed out over a slight down grade in the road. Car began to shake. I was only 4 blocks from my house so I made it home. The next day I tried to start the car and it turned over then stalled. I never had any problems with the car mechanically or with the engine. Someone mentioned to me that I might of thrown off the timing belt. Any suggestions and what am I looking at to repair the car?
Thx's,
Bob
Apr 12, 2017 at 11:41 AM (Merged)
  • 75,988 POSTS
Hi rmonkelis, Welcome to 2carpros and TY for the donation
Do below to determine if its a spark, fuel and compression problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
RMONKELIS
Your response of how I would diagnois the problem although helpful does not help me. Because either way I have to take the car to a mechanic and have him tell me how he would fix it. So, I would like to know more specifically in your professional opinion what would cause the car to shake after a scrap on a low spot in the road / leading up to the car not wanting to start the next day? Can you give me three suggestions knowing that the car neverr had any engine problems until the scrap / bottom out (Assuming the car was in good working order for all parts). Mechanically what would cause that to happen?
Thank you,
Bob
  • 75,988 POSTS
Could be a connection that came loose and not making good contact such as the fuel pump connector, T-belt could have jumped, Overall an electrical connection problem
