1986 Mazda B2000 Wobbly Crankshaft Fix
FIREDANCINGPHOENIX
Hey there, I've got a 86 B2000 (2.0L engine) with 120K miles and a "wobbly" crankshaft (looks bent-- possibly a bad repair of timing belt from previous owner?) I'm guessing I need to replace the whole engine, but I hear the B2000's are notoriously bad engines, and also not easily switched with another model. Wondering if I need to find another 2.0L B2000 replacement engine, or could I fit a B2200, or for that matter, any other make or model of engine? I'm scouting for a decent salvage engine to replace mine, but I'm not sure WHICH engines would be acceptable replacements, or if I do need to find a B2000, specifically. Anyone know? Thanks! :?:
Aug 7, 2007 at 7:35 AM
  • 75,988 POSTS
[quote:3bbeb624a1="FiredancingPhoenix"]Hey there, I've got a 86 B2000 (2.0L engine) with 120K miles and a "wobbly" crankshaft (looks bent-- possibly a bad repair of timing belt from previous owner?) I'm guessing I need to replace the whole engine, but I hear the B2000's are notoriously bad engines, and also not easily switched with another model. Wondering if I need to find another 2.0L B2000 replacement engine, or could I fit a B2200, or for that matter, any other make or model of engine? I'm scouting for a decent salvage engine to replace mine, but I'm not sure WHICH engines would be acceptable replacements, or if I do need to find a B2000, specifically. Anyone know? Thanks! :?:[/quote:3bbeb624a1]
A 2.2L will work
Aug 18, 2007 at 10:29 AM
Suggested Repair
Replace the damaged 2.0L engine with a compatible 2.2L engine, which the expert says will work.
Conversation Summary
The owner of a 1986 Mazda B2000 with a wobbly, possibly bent crankshaft asked whether a 2.0L B2000 engine is required or if a B2200 2.2L or another engine could be used. The expert replied that a 2.2L engine will work.
