George in Mississippi :?:
1999 Mazda B3000 Won't Start
If this is not the case then I would lean towards the starter...btw 99 b300's do NOT have starter solenoids o nthe fender
Cosmo
Suggested Repair
With the key in ON or START, check whether the anti-theft light flashes rapidly; if it does, suspect a key programming fault and confirm the original truck keys are being used. If the theft light is not flashing, check the starter relay near the battery and the starter. Note that a 1999 B3000 does not have a starter solenoid on the fender.
Conversation Summary
The owner inherited a 1999 B3000 that will not start. The battery appears okay, the ignition powers the electrical system, the clutch is depressed, and the truck has passive anti-theft keys. Experts advised checking for a rapidly flashing theft light and possible key programming fault, then checking the starter relay near the battery or a bad starter, and noted these trucks do not have a fender-mounted starter solenoid.
