1990 Mazda Truck vehicle won't start
RA15718610
  • 1990 MAZDA TRUCK
  • 4 CYL
  • 4WD
  • 117,000 MILES
The problem started when I noticed a slight miss at idle that would disappear at 1000 rpm and up. Shortly after, the vehicle would barely run. It appeared to be running on only 2 cylinders and would only go about 30 mph. I changed the plugs, new wires, new cap and rotor, and a new battery. After that the vehicle failed to start. I'm getting spark at the plug and off the coil. I'm getting gas from the filter to the injectors. I checked the firing order and did a cold compression check (since engine won't start) and get between 150-170 lbs. The plugs appear to be wet with gas, yet won't fire. I changed the plugs from autolite to NGK with negative results. I checked ECM and discovered a burnt spot. I sent the ECM to Texas and had it upgraded and repaired. They test the unit by installing it in a vehicle and letting it run.
I'm at a total loss! I'm not sure if a sensor could be causing the problem. Could a mass air flow sensor, throttle position sensor, or oxygen sensor cause the vehicle not to start or even sputter? Could it be a crank or cam angle sensor. Does my year and model have these sensors. Your help would be deeply appreciated.
Thanks,
Steve
Thursday, February 7th, 2008 AT 11:45 AM
Do you have a check engine light On or has flashed?
When was the last tune-up?
For a start lets get the fuel pressure and the exhaust system checked for correct pressure and restriction in the exhaust system and also the throttle position sensor.
Thursday, February 7th, 2008 AT 12:46 PM
RA15718610
I didn't get any check engine lights. Recent tune up when I replaced all the ingition components. I removed the hose that exits the fuel filter to the injector rail and cranked the engine. Fuel flows freely. With the plugs out and cranking the engine, I can detect the fuel spray in to the cylinders. Will a faulty throttel position sensor cause not to startor sputter at all?
Thanks,
Steve
Friday, February 8th, 2008 AT 6:46 AM
You sure its not flooding out-check the actual fuel pressure with a fuel pressure gauge and comeback with the readings-could be an excessive pressive or the pressure regulator is leaking-
Friday, February 8th, 2008 AT 12:15 PM
RA15718610
I haven't checked the fuel presure as of yet since my starter quit. I have to replace it before any checks can be made. However, does my Mazda have a cam angle sensor or a crank angle sensor?
Thanks,
Steve
Friday, February 15th, 2008 AT 6:45 AM
No it doesn't have it-
On the 2200/26000 for an ignition system Optical distributor/pick-up and ignitor in the distributor.
Friday, February 15th, 2008 AT 9:03 AM
