1993 Mazda B2600i Brake Replacement
TNALARTRAV
I have a 1993 Mazda B2600i with 180000 miles. I'm starting to replace the front and rear brakes. I am trying to find out if I should replace the wheel cylinder on the rear and/or the calipers on the front even if there is no sign of leakage. Also should the return springs be replaced.
I read on one repair site where the person advised replacing the cylinder when changing the drums and shoes as the new parts will be thicker and drive the inner parts of the wheel cyclinder back to the middle where there is probably dust and other junk that would cause problems down the road (leaking I believe is what he said).
I have also seen where vehicles with high mileage shouldn't replace the brake fluid because of worn parts not moving correctly with all new fluid. The brake fluid should only be topped off. Is this correct?
I want to do this right the first time and not have any reason to take it to a shop (cost almost more than the vehicle is worth).
Thank you,
Jeff
Jul 28, 2007 at 4:55 PM
  • 75,988 POSTS
[quote:7d7fdf8170="TNALARTRAV"]I have a 1993 Mazda B2600i with 180000 miles. I'm starting to replace the front and rear brakes. I am trying to find out if I should replace the wheel cylinder on the rear and/or the calipers on the front even if there is no sign of leakage. Also should the return springs be replaced.
Thank you,
Jeff[/quote:7d7fdf8170]
Determination/Funding is available I'll shoot the moon to see another 180,000miles or more, Fluid, change it and do it right.
BTW you forgot the master cylinder
Jul 28, 2007 at 9:37 PM
TNALARTRAV
What about the springs and wheel cylinders/ calipers.
Jul 29, 2007 at 6:14 AM
  • 75,988 POSTS
[quote:eb16aa2155="TNALARTRAV"]What about the springs and wheel cylinders/ calipers.[/quote:eb16aa2155]
If you want to save benjamins you can do a rain check on the whl cyl. and cal's if its not leaking.but I'll change the springs.
Jul 29, 2007 at 10:19 AM
Suggested Repair
Change the brake fluid rather than only topping it off, and replace the return springs. Wheel cylinders and calipers can be left in place if they are not leaking. Also consider the master cylinder.
Conversation Summary
The owner of a 1993 Mazda B2600i with 180,000 miles is replacing front and rear brakes and asked whether to replace non-leaking rear wheel cylinders and front calipers, whether to replace return springs, and whether high-mileage brake fluid should only be topped off. The expert advised changing the fluid properly, replacing the springs, and considering the master cylinder, while saying the wheel cylinders and calipers can be deferred if they are not leaking.
