1993 Mazda Protege Brake Line Leak
LL DA GOD
1993 Mazda Protege LX 140,000 miles
hi, my car has a brake problem. the warning light for brakes stays on, so i check the fluid and found it was gone. so i replaced it and tried testing the brakes. they maintain normal pressure for only a few moments then went strtaight to the floor. I checked underneath and all the fluid leaked out. I've been told tht this is caused by messed master cylinder. but when i looked under the car i notced the brake fluid was also on these pipes to the rear(brake lines?) how can i be sure exactly what the problem is and what is the best course of action?
Thanks in advance.
Dec 22, 2006 at 7:14 AM
MATHIASO
  • 1,209 POSTS
You do have leaks on your brakes line, remove the leaking line and take it to an auto parts store to buy the right lengh one. do not forget to bleed the brakes after replacement.
Dec 23, 2006 at 12:36 PM
COSMO
  • 347 POSTS
The year protege you have loves to get brake line leaks around the top of the fuel tank and near the firewall when it turns to go under the vehicle.
More than likely if you have this leak, it is easier to just replace both brake lines to tthe back and then replace the lines to eiter rear wheel (they will probably be in just as bad of shape).
Most times I would say make your own lines, but I think the lines only cost $35 cnd each....so why both with making the lines when you can bu ythe ones from your local Mazda dealer that are the right leangth and have all the correct bends in them. I myself have done this to my own protege years ago.
Good luck, its a messy job
Cosmo...Mazda TEch
Dec 24, 2006 at 10:56 AM
Suggested Repair
Replace the leaking rear brake lines, including both lines to the rear and the lines to each rear wheel. Pre-bent lines from a Mazda dealer are preferred over homemade lines. After replacement, bleed the brake system.
Conversation Summary
The owner of a 1993 Mazda Protege reported a brake warning light, lost brake fluid, and a pedal that went to the floor after fluid was added. Fluid was leaking onto the rear brake lines. Experts said the leak is in the brake lines, a common Protege issue near the fuel tank and firewall, and recommended replacing the rear lines with dealer lines of the correct length and bends, then bleeding the brakes.
