1995 Mazda Protege squeeling
13,848 MILES • 4 CYL • FWD • MANUAL
SKYHIGH1597
I changed my brake calipers due to them sticking and they started squeeling a little. I lifted the car and pulled the brake dust shields off which helped some. Now though, its not constant like before. i can only hear it at lower speeds and its very annoying. Also my brakes are very soft. I bledthem twice and the pedal still almost hits the floor. Is it my master cylinder or my power booster?
May 12, 2008 at 4:08 AM
BMRFIXIT
  • 19,053 POSTS
check make sure rear brakes in good condition and adjusted
check for air in system front and rear
and if still no pedal suspect master cylinder
May 14, 2008 at 11:21 PM
SKYHIGH1597
how does the rear brakes effect my pdal like that so much? Im sure they need to be replaced or adjusted as i havent done them and to my current knowledge they have never been done. There is no air in the lines though. i bled them for a third time just to be sure. thanks though for notifying me anout the rear, never thought of that.
May 15, 2008 at 8:44 AM
BMRFIXIT
  • 19,053 POSTS
The pedal have to travel more for it to make connection with the drums
May 15, 2008 at 1:34 PM
