2003 Mazda Protege Brake Light On
MINIMICH29
I have a 2003 Mazda Protege (Standard Transmission), 55,364 miles
My emergency brake light comes on when I brake 'hard' or come to a complete stop suddenly (like coming upon sudden traffic), but the emergency brake is not on. WHY? This just started the other day and I am a bit concerned. Please help.
THANKS!!!
Dec 5, 2006 at 12:24 AM
COSMO
  • 347 POSTS
Go check your brake fluid level, this is not just an emergency brake light. It also lets you know when you are low on fluid. So you are probably low on brakes too!
Cosmo...Mazda Tech
Dec 5, 2006 at 3:29 AM
Suggested Repair
Check the brake fluid level. The warning light also indicates low fluid, so top it up if low and inspect for a leak or worn brakes.
Conversation Summary
The owner of a 2003 Mazda Protege with a manual transmission reports that the emergency brake light comes on during hard braking or sudden stops even though the parking brake is not applied. A Mazda technician advises checking the brake fluid level, because the same light warns of low fluid and the brakes may be low.
